My DCS-RG-364GL oven doesn't light
Dave415
When I turn on the oven the igniter turns on and after 30 seconds the gas comes on. I can smell gas but it doesn't light.
I have replaced the igniter with the same results. If I gently blow on the igniter while the gas is on the gas will ignite.
Any thoughts? Thanks, Dave.
  • Replies 4
  • AccApp
  • Dave415
  • certified tech group 51
What condition is the burner tube in? Is it properly positioned? Did you use the correct igniter?
The burner tube seems in good shape. I took it out and cleaned the holes. Nothing seemed wrong. I used an aftermarket lighter that replaced the factory 211541 lighter.
