LRG3081ST/00
ameritech
Manufacturer: LG
Type of Appliance: Gas Range
Model Number: LRG3081ST/00
Going out on an LG Gas range. Had a little trouble pulling up exact MOD but this was straight off the sticker on unit... LRG3081ST/00
Went ahead and brushed up on Samurai's gas oven video that just showed up in my email. Lots of good info : )
Jared
AmeriTech
  • Replies 4
  • ameritech
  • Chat_in_FL
Posted Images
What is the issue/symptom?
Found following, but no specific service manual:
SERVICE BULLETINS
Bulletin #
Subject
HGOR20150018 Fan Not working [~412MMXXxxxx]
0GOR20150083 Knob change- Gas Models
0GOR20150076 Print color change
0GOR20150086 Cable Assembly changed to blue color
0GOR20150073 Top Plate Assembly Screw Holes Quantity Reduction
Oven not heating. F9 error. Cust says he took the pan and spreader off and igniter wasn’t glowing at all. Apparently F9 is is no heat or not up to temp soon enough.
I found a post here on a similar model where  one of the guys said that LG updated the brackets for the thermal fuses, to where they would sit up higher off the body so they wouldn’t blow so easily. So I’ve got a little bit to go off... Any more ideas?
Thanks for looking...
