Frigidaire Dryer loud noise after replacing glides and felt Model FDE436RES1
stevie1990
The glides had broken on my dryer, and the lower felt was rust colored, so I replaced both of them. I have done this several times without a problem. This time, when I put everything back together and started the dryer, it started to emit a loud squeal that I can't pinpoint. Does anyone have an idea of what might be causing this issue?
on that dryer ,most of the time squealing noises come from the rear bearing needing greased or replaced if wore to much
yes, rear bearing wearing out is common on these, it comes as a kit(5303281153) with the steel ball, a plastic bearing, a holder, a ball bearing to act as a ground, etc Don't just buy the plastic bearing. It could also be the idler pulley.
I bought the rear bearing kit (5303281153) and replaced it. The idler pulley had a crack in the wheel, so I bought and replaced the wheel as well. Unfortunately, the squeal continues. I do appreciate the information.
Something in the blower, run it without the belt hooked up and see if it's the motor
When I ran it without the belt, the noise was gone.
At this point i would take it apart again and go over everything with i fine tooth comb.
Sounds like drum bearing may not be seated in bearing cup.
You inserted little ball bearing in cup, correct?
Yes, I did insert the ball bearing in the cup. Luckily, I had a helper who was able to hold the piece in the back while I placed the cup with the ball bearing in the front.
Before I took the dryer apart again, I noticed that the idler pulley and the shaft coming off the motor were really dirty. Once I cleaned them off, the squeal stopped. Thanks again for your help, everyone.
Yes, that can be tricky without a helper.
A spot of grease holds ball in cup.
But still tricky reaching around cabinet.
Edited by 16345Ed
That is a great tip! I will do that next time.
