Need service manual for Frigidaire M# FGHB2866PFGA
Quick
Manufacturer: Frigidaire
Type of Appliance: FDBM
Model Number: FGHB2866PFGA
I got the tech sheet off the box.
Maybe I'm just stupid. But be damned if I can get it into the Ice Maker diagnostic mode.
Sounds like you just had the schematic. Tech sheet shows how to manually cycle both ice makers:
What you just provided for me Scott states entry into Ice Maker Diagnostic Mode as Press ٨ and + temperature pads for up to 10 sec. simultaneously.
I have in my possession the tech sheet I took from the refrigerator itself.  But here's how entry into Ice Maker Diagnostic reads on what I have in my hand now...Press ( shows the little arrow up) and ( shows the little arrow down) temperature pads for up to 10 sec. simultaneously.  See the difference?
I have Service Data Sheet A01544601 right out from under the box. And the kick plate is horrible putting back into place.
Appreciate you my brother.
Follow up to say the tech sheet provided with the refrigerator had the WRONG instructions printed on it. The ice maker (diagnostic key dance) was wrong! The tech sheet above that Scott provided me had the correct key dance. I made notes on the tech sheet and put it back under the box for the next tech...
  • 9 months later...
Wanted to pass this on. I ran a Frigidaire Gallery Refrigerator call yesterday. M# FGHC2331PFCA
I could not get it to go into diagnostics.
The key dance to enter was wrong on both the tech sheet I downloaded and brought with me , and wrong on the tech sheet behind the kick plate.
Instructions said to hold the temperature up and down key pads for 10 secs! WRONG! You have to hold the option up and down key pads for 10 seconds to enter.
This is the second time I've encountered a Frigidaire Refrigerator with wrong tech info...
