Water leak Kenmore 106.74254401
acparla
Kenmore 106.74254401 Refrigerator.
Water leaking into fridge, but no idea how.
No water hooked up to Fridge. This is a unit with accessible  water hook ups but no line attached.
Water pools on bottom shelf. Frost free Freezer.
YouTube Refrigerator defrost drain.
Correct, as our friend Quick has pointed out you likely have a clogged evaporator drain. Your unit defrosts itself a couple times a day and creates water doing so, if the drain freezes the water can not go down the drain so it flows into your refrigerator, via air vents.
Point of information for you if it turns out your defrost drain is clear and your scratching your head I have a little story of a job I had gone to when I first started.      I had a call that there was water in the bottom of the fridge below the crisper draws and on the top shelf in the back.  I emptied out the top of the fridge and could see the water on the top shelf in the back.   I thought it was definitely  a frozen drain line.  It turned out not to be a frozen drain line and it was draining fine in the defrost cycle.  I'm scratching my head like Oh man !  where is this water coming from . I started to put things back into the fridge and then when I picked up the brita filtered water container that I placed on the counter from the fridge, there was water all on the counter top under the water container.   Apparently there was a tiny crack in the container which was not leaking when you picked it up.  It only leaked when it was placed down on a surface.  Go figure.  After that I always checked the items in the fridge first for possible leaks.    Just something for you to consider when you go to a leaking fridge call. :)
Had a call for a washer leaking, but not every time it ran. Ran it and looked all over for the leak. Could not see any signs of a leak in the cabinet. If I shined my light just right I could see the old water trace on the floor. I followed it behind the dryer to the pantry. Found an unopened water jug that was starting to collapse. It was not leaking at the time. The customer made a good observation. It only leaked depending on what the barometric pressure was since it was still sealed.
