596.73502203 Kenmore Bottom Freezer Gourmet Pantry (Bottom tray) freezes vegetable on left side only
HN3
Model No: 596.73502203
Hi,
I posted this help request at another appliance repair forum for about three weeks now and there was no response.  I am hoping you can help me.
My refrigerator's bottom tray (manual calls it Gourmet Pantry) freezes vegetables stored on the back left side only. I have noticed this for a several months now.
There is a temperature control for this tray and it is set at the highest setting (bottom of slider control).
What is causing this and how do I fix it?
Some information in case it help: This fridge was stored unplugged in the garage for two years and I took it up to use it again last year. I don't recall any freezing problems when I used the fridge before storing it in the garage.  There is an icemaker for this model and it is in the freezer.
Thank you in advance for your time and help.
  • Replies 4
  • HN3
  • Lighthouse
I am not finding a tech sheet on this model. Is the tray control just a slide control that opens & closes a vent? Could be that it is not actually moving anything.
Hi,
Thank you for responding.
I tried to move the slide control back up to the colder temperature but it kept sliding back down.  So something is not moving.  I recalled that it was not at the bottom (warmest temp setting) when I slide it down to the bottom.  There is a covering so I am not able to see if anything is blocking it from moving.
I do have the user manual if you want  me to take photos of it and upload that.
If you have any suggestion, please let me know.
Thanks,
Hoang
Could be your problem there. May be broke and actully be on coldest setting. Would need to get to where you can take a good look at it.
Not what I was looking for. Wouldn't help
Hi,
Thank you for responding again.
I will have to hold off on this for a while since I am starting to re-roof my house.
When I get a chance I will see if I can open it and see why the slider is stuck and report back.
Thanks again for your time and help.
Hoang
