Kitchenaid wall oven door needed!
StacyTConnor
  • Replies 8
  • StacyTConnor
  • J5*
  • Econo Appliance
  • evaappliance
You can’t get the whole door in one piece , econo gave you the correct part # for the door front ,but you will have to order anything else individually.  It will be insanely high to do that.
StacyTConnor
I have come to understand that you can't just buy a whole door... you know how there is junk yards for cars?... is there such a thing for appliances? I'm hoping to find a door off an oven that perhaps has been replaced for some reason. (the rough quote to build a door piece by piece is approximately $1,000!).  Craziness. :angry:
StacyTConnor
Instead of scrapping the oven we decided to keep it to see if we could locate a door. We may just have to give up on the idea. It’s a shame.
