KFXS25RYMS4
herfdog
Is there a heater or something to stop the freezer drain from freezing up and overflowing? The evaporator defrost function is working properly.
  • Replies 5
  • herfdog
  • 16345Ed
  • Lighthouse
  • Rhubarb Tau
I don't know of a factory drain heater, but I've used the aluminum drain probe from the Samsung leakage kit DA82-01415A .
This unit also is subject to the P-Trap bulletin W10632338B , which can cause frozen defrost drains from guk glueing the original duckbill shut , calls for replacing the duckbill with P-Trap W10619951
Yes to this...
Someone on here turned me on to aluminum fence ties for drain probes. Easy  to bend, shape and cut to size. Cheap.
I keep a couple of the Samsung drain heaters on the truck.
Part number: AP5579885
I keep a bag of the fence ties in my steamer bag. I have used them on the units that the above doesn't work on.
As stated above this particular unit most likely needs the P-Trap update.
Part number: AP5780744
Also carry this on truck
Part number: AP3119957
