Maytag Neptune Tech Sheet MAH5500BWW
1manoperation97
1manoperation97
Manufacturer: Maytag
Type of Appliance: Washer, Neptune
Model Number: MAH5500BWW
I've looked this up on several sites, they don't give a tech sheet number, they give the service manual number 16010061. I've got that. Unless I've looked over it, I can't find how to get this particular model into test mode. The tech sheet is missing from the washer. Thanks.
  • Son of Samurai
  • 1manoperation97
Posted Images
Very sparse information on this one. The best I could find on Service Matters was this Parts List, which contains a schematic. They didn't even have the service manual you had mentioned on the site.
Never mind, I poked around a little more and found this one for you. Looks like it's got the service mode entry instructions you were looking for.
