Frigidaire Refrigerator FPBC2277RF5 Manual
mqcmcousin
mqcmcousin
Manufacturer: Electrolux
Model Number: FPBC2277RF5
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Requesting Service Manual/Tech Sheet please.
  • Replies 4
  • Lighthouse
  • Rhubarb Tau
  • Joe B, Stoughton Appliance Repair
  • mqcmcousin
Uses this tech sheet
If you need a Frigidaire Service manual check this out
  • 10 months later...
2 hours ago, deezus said:
This doesn't show any testing info for upper icemaker.
There's a box in the center of it labelled "FRESH FOOD ICE MAKER DIAGNOSTIC MODE", and you can test the Icemaker Defrost Heater in normal Service Mode.
If you haven't run across many of these, search the site for "Frigidaire FFIM Air Handler" for several known issues.
  • 3 years later...
Adding this post, just figured this out
Fresh food Icemaker test mode will not initiate if icemaker is turned off.
Icemaker needs be turned on to access test mode.  “Ice on”
