Kitchenaid refer manual request
Scott-afl
Manufacturer: Kitchenaid
Model Number: krsc503ess00
I searched the full model whittled down to krsc*, and found no manual online. As stated,  I did verify model number.
Sometimes you can play with the first letter on WP models to get it to go. (W - Whirlpool, K - Kitchen aid, M - Maytag)
Here is the TS
Also could have found it by using this method
