GE RANGE JSP42DN2BB Burner replacement
applianceman1
Manufacturer: Ge
Type of Appliance: Range
Model Number: JSP42DN2BB
Looking for service manual.
Need to take top off to replace element.
Thanks
  • Replies 1
  • applianceman1
  • Son of Samurai
The mini manual that we have for this model in the Downloads section contains some instructions on removing the cooktop. Looks like you have to remove the control panel first. Have you taken a look at that file?
