Samsung RS261MDWP
Lighthouse
Manufacturer: Samsung
Model Number: RS261MDWP
looking for FT &/or SM
Thanks
  • Replies 4
  • Lighthouse
Uses this one
Hmm, I typed in RS261* but didn’t see the one for M. Oh well, thanks!!!
No problem! Weird it didn’t pull up for you. You may not have selected the Files section in the search box. I just tried it to make sure the search function is working correctly.
I didn’t select files section because I was looking at topics also
