Bosch Manual Request SHS5AVL5UC
Dr. Phil
Manufacturer: Bosch
Type of Appliance: Dishwasher
Model Number: SHS5AVL5UC
Thanks
  • Son of Samurai
  • Dr. Phil
There should be a slash followed by a couple of numbers at the end there. Could you double check that?
