Tech sheet or service manual?
dave316
Manufacturer: Frigidaire
Model Number: FFTR1514QW4
Can manually defrost in service mode and defrosts for a few minutes. Has panel frosted over  in freezer.
  • dave316
  • Son of Samurai
Thanks will try that.
Ended up replacing control assembly with thermistor and evap motor. Control assembly had bugs.
  • 3 weeks later...
Update still not defrosting right.has a wiring harness where it comes with a thermister and defrost thermostat wired on it .just the way its made I guess . I got it ordered.this should definitely complete repair.good thing I work for someone who would rather  have something repaired then always buying new .lol
Edited by dave316
