Samsung Ice Room Mishap
tbjohnson62
Manufacturer: Samsung
Model Number: RF28HFEDBSR/AA0001
Customer tried to solve Ice Room freezing problem with a heat gun. I am trying to locate the replacement part number of the melted component. I have looked at parts breakdowns I could find and have not found a part number. Any help from the wise participants of this great site would be appreciated.
Thank You.
Link to comment
If you found the right parts diagram and it’s not listed then it’s unlikely going to be available
is the part removable ?
your only choice may be a scrapped unit
Link to comment
The ice maker works but is not aligned correctly and water from the fill tube is splashing out causing ice buildup to block air from the fan causing no ice production.
The part does look removable with 3 screws holding it on.
I will search for dead unit.
Thanks for your help.
Link to comment
The ice room is damaged, it's part of the cabinet, non-serviceable part. Here are pixs of a ice maker I had a very hard time removing from a Samsung's top of the line 4-door refrigerator, this refrigerator has the large LCD panel in door and has the processing power of a small laptop and the owner torched it with some sort of hair dryer/heat gun.
Link to comment
