Admiral air conditioner info and parts
ctwatersjr
ctwatersjr
This is driving me nuts!!!  I can't find any info PERIOD on Admiral air conditioners.  I can't adjust the temp on this one.  HELP!!!!!!!!!!!!!!!!!!!!!!!!!
  • Replies 5
Then you'll have to improvise, adapt, overcome. Go to the junk yard and get any old cold control that looks similar (or get several in case one is bad) and adapt it to fit your unit. Use the creativity and ingenuity that God gave you. Then come back and post your happy ending.
Guest ahammer48
Hello
Is this a window unit?? If so remove the thermostat and take it to a company called Johnstone Supply They should be able to help U but they have become very strict about selling 2 laymen.
Any refrigeration supply house should be able to fix U up with a universal thermostat.
Hope that helps:)
I bet you tahats a montgomery wards ac with admiral wrote on it ...whats the model number does it start with uan?
