Bosch B22CS30SNS/01
Confluence
Hello,
My freezer stopped holding temperature but my refrigerator still holds 41 degrees. From reading the other posts on your site it looks like the invert PCB needs to be replaced, is that accurate if the refrigerator is still staying cold or perhaps something else is wrong?
The freezer fan does turn on when I hold down the door switch. Thanks!
  • LearningTech
  • Confluence
Likely something else,... a defrost problem?
if the inverter goes bad then the fridge and freezer will stop working. You may notice the freezer fail first , but both go bad.
Edited by LearningTech
The freezer started working again randomly... what could cause the freezer to lose temperature, but the freezer fan continued working and the refrigerator continued to operate normally?
Restriction in the sealed system( expensive)
defrost issue.
 Something blocking airflow
3way refrigerant valve
