PFE28KSKDSS Service manual needed
mraswm
Manufacturer: Ge
Model Number: PFE28KSKDSS
Service manual needed for PFE28KSKDSS. Suspect defrost issue, not sure where to check. Frost line back to compressor.
  • Replies 1
  • mraswm
Minimanual is all you need for diagnostics, has diagnostic mode entry, error codes, and schematics.
If you need more troubleshooting help, be glad to help you in the Appliance Repair Tech Forum, just start a new topic there.
