Whirlpool Refrigerator WRX735sdbm03
mqcmcousin
Manufacturer: Whirlpool
Model Number: WRX735sdbm03
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Request Tech Sheet/Service Manual please.
  • Replies 4
  • mqcmcousin
  • Son of Samurai
1 hour ago, mqcmcousin said:
Try searching the Downloads section again. If you take off the last couple characters in the model number and replace them with the * wildcard, then you'll pull up the tech sheet.
OK, did that but I didn't think it was the right tech sheet because it didn't match the pub number from the Sears website. This fridge also has a different part number IM which is what I'm going on the call for.
Edited by mqcmcousin
Here, this tech sheet is based on the pub number I found for this model on Whirlpool's site:
And here's the service manual -- should have info on the ice maker.
