Repair Broken Shelf Runner for 632 SunbZero Freezer
richt
Hello Appliance Repair Masters,
The right side shelf runner on our SubZero Freezer that holds the drawer for ice has broken.  It looks like a simple repair with two phillips screw drivers to remove and replace.  Could you let me know a link where I can get a replacement and are there any "watch outs" I'm missing in terms of the repair?
Thanks as always!
  • richt
  • AccApp
  • 16345Ed
I just did one of these last month. Call sub zero 800-222-7820  and they will give you your local, territory exclusive parts distributor. Easy-peasy
