Ge Dryer manual
deezus
Manufacturer: GE
Type of Appliance: Dryer
Model Number: gfdn160ejww
Need this manual. I can't figure out how to take these new GE dryers apart.
Thanks
2 minutes ago, 16345Ed said:
@coolhandluke
Does mini manual have disassembly info?
its mini manual no: 31-16895
I don't see that file number.
It was listed on searspartsdirect.com in parts diagram?  That’s where I grabbed it from anyway.
Does it show how to remove the top? If so can you give me a link?
Thanks.
Edited by deezus
This is not that unit. This one has no screws on top its newer. I'm familiar with that one you posted.
I don't think that's gonna help. I need service manual or someone to tell me how to take unit apart.
I can't say for sure, but I've run into a couple of front-load GE's (washers, but might be similar) that had me stumped for disassembly for a while. No screws on the back of the top panel. There's a hidden screw (on these, anyway) behind the cycle knob, and a couple others in the dispenser tray (again, these were washers, not sure for dryers). Once all the screws were out, I think the console lifted straight up off clips, then the top panel screws were along the front edge behind the console.
I can't find any other minii-manuals for that model that give any help on disassembly. :(
Edited by Rhubarb Tau
removed extra text
Yep I done a few of those kind too... forgot about them.
59 minutes ago, deezus said:
Is that it?
Yep as I recall pull off knob, remove that screw and then carefully pry console off from top.
