Kenmore Refrigerator model 795.70323311 no power
alexuyen
I have a Kenmore Refrigerator Model  795.70323311 that has no power when plugged and turned on.  Replaced Main PCB board and still no luck.  Please help provide step-by-step instructions to troubleshoot.  Thanks.
  • alexuyen
  • TheHelicopterKid
Did you happen to test the outlet and check breaker? Covering the simple stuff first.
