TECH SHEET/ SVC MANUAL PSF26MGWCC
MsAnn
Manufacturer: GE
Type of Appliance: REFRIG
Model Number: PFS26MGWCC
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
I saw this tech sheet and I am not sure it works with this model number. If not can you locate the tech sheet I need. Thank you for your help.
 I think there's a typo in that model number. Paste that into Repairclinic and you'll see what I mean.
you are so right! the model number should be PSF26MGWW. Sorry for the mistake. Do I need to resubmit the request?
No problem! I’ll look it up for you and post it in a bit.
Uses same tech sheet as this model:
