Thermador oven ML# pg486gebs/11
HUB knife
HUB knife
My oven will not turn on. There are blue blinking lights that indicate the error code. The left light which says oven blinks twice. Then the right light which says heating blinks once.
Does anyone know what error code this is so I can order a part.
  • Replies 1
  • 16345Ed
  • HUB knife
Potentiometer failure. Check all connections if ok replace potentiometer.
