New Appliance Service Manual added: GE Front Control Gas Ranges Training Bulletin - Shuts Down at 250 degrees F
View File
Bake and Broil operations shut down when temperature reaches approximately 250F.
If the selected bake or broil function operates briefly, then shuts down, the problem is not likely with the ERC. A problem may exist with the cooling blower motor or the motor wiring.
Models affected:
C2S995SEL, PGS960BEL, PGS960EEL, PGS960FEL, PGS960SEL, CGS995EEL, CGS995SEL
Serial numbers: All
PUB TB17-18
  • Replies 0
