kitchenaid KSCS23ftSS02 compressor will not start
RocketRob
Hi there, newbie Rob here, what an awesome resource here!
Bought this fridge as not working for 50 bucks. It fully lights up inside and all temp controls are working as well as fan behind the compressor. This is my 1st shot at fridge repair, so I took the bait that if the compressor was not shorted, high likelyhood the inverter was blown. Checked compressor resistance as well. all 3 phases identical at approx 70 ohms. Ordered the new inverter. In the box was a tip sheet that said be sure the 5v from the control board is present at the input to the Inverter, or it will not run. I checked for this voltage and it was not present. disconnected 5v cable from inverter, rechecked. Still no 5v. I buzzed the 5v line back to the output from the control board and path is closed with no ground shorts. Pulled the control board, The infamous W10219463, but cant find any physical symptoms of a failure. I have no idea where to find a schematic for this board to try and troubleshoot at card level. I tried an online parts bag deal. 4 relays and a 220microfarad cap. replaced these parts and still no joy. all symptoms remain the same.would be grateful if anyone has come across this failure symptom. I suppose I could send my board in for repair, but I hate to give in, especially if its just a blown relay, cap or diode. Or not a problem of control board at all? Thanks for taking a look!
  • Replies 5
  • RocketRob
  • Budget Appliance Repair
  • PenlopePendleton
This doesn't sound right - are you sure it was 70 Ohms?    If I'm correct I think each phase should be 7 to 10 Ohms, any chance your meter was on the wrong setting?
You will not get or find any schematics for board level repair for any appliances except LG and Samsung, (it could be just one or the other of those two - I don't remember.   Which ever one it is they actually have schematics of each part of the board down to component level).
Thanks Willie, you were right about compressor winding resistance.  It was a week ago and I misplaced a decimal point. I just rechecked. Each winding measures 6.6 ohms and no shorts, so compressor is ok.
Without any resources, I guess Im going to have to replace the control board, or send it into one of these online repair places. I checked about the schematics. yes, both LG and Samsung are available through websites , not a whisper of anything kitchenaid or whirlpool
Appliance manufactures are pretty much know for Black Boxing there boards - if you want to do board level repair you have to know what your doing and figure it out on your own as far as the manufactures are concerned.
I was really surprised at the detail for each electronic circuit on the boards in Samsung? and/or LG? products in their service manuals.
  • 2 months later...
PenlopePendleton
You know this doesn't have to be rebuilt anymore.. Right?  They have been making the replacement for this control and the one ending with 462 for a couple of years now.
