New Appliance Service Manual added: GE Refrigerator Main Control Board Replacement and Cutting J1 pin 2
Captain Dunsel
View File
If the control board is vertically mounted AND there are wires in both pin 1 and pin 2 of J1, then J1 pin 2 must be cut to replace the board.
  • Replies 0
  • Captain Dunsel
