Kenmore Refrigerator Tech sheet needed
FrMircea
Manufacturer: Kenmore
Model Number: 59672912200
Found a tech sheet for a similar model. Had to remove last 6 digits. Not sure if it's accurate.
Fridge with warm FF.
Thanks!
  • FrMircea
  • Son of Samurai
  • Captain Dunsel
Posted Images
 Sears Parts Says your tech sheet number is 12642404 and I just uploaded it.No electronic on this one! It will be similar to this service manual.
Thanks, Cap!
I ended up going in with no tech sheet. Very basic system.
The defrost thermostat failed. Ice build up around evap coils restricting air flow through damper to FF.
