Better suspension rods for WA5451ANW/XAA2 Samsung
dave42
Our Samsung washer goes out of balance with every load of laundry. I know I need to replace the suspension rods. The ones I find are DC97-16350C. But I’ve read that there are sturdier ones that are aftermarket. Does anyone know where to go for alternate part numbers?  Repair Clinic only lists the above ones. Thanks
Aftermarket rods are usually junk in my experience. Go with the OEM replacements and it will work great if you’re loading it correctly
  • 3 years later...
exactly Ethan.  I always go with OEM Especially with Samsung parts.
