Samsung washer occasionally leaks
boost505
Hello, I have a Samsung front loader (WF42H5000A) that occasionally leaks while running.  The strange thing is that it does not leak every time, just occasionally.
The first time it leaked I found the filter completely clogged, so I figured that would resolve the problem once cleared.
The second time, I found a key in the filter (but it was otherwise clear).
This last time I found hairband in the filter (but it was otherwise clear)
In between these incidents the washer has run without issue multiple times.  I suspect the problem is with a loose drain hose, but I figured before I tear the machine apart tonight, I'd ask if anyone has experienced these symptoms and can narrow down my troubleshooting.  Thanks in advance for any help.
  • Replies 5
  • darren412
  • 16345Ed
  • EthanRanft
  • boost505
Sounds like a lot of stuff from the clothing  is getting into your filter more than it really should.  You may want to check the articals of clothing a little better with every wash load. Once you start getting alot of different types of things accumulating in your filter , it increases the chance of something piercing and going through the tub to pump hose and then lodging itself in there.  and causing a real slow and tiny leak.   I would check the tub to pump hose thoroughly for something that may have penetrated the hose and is possibly slowly leaking from intermittent movement during the different cycles. Just an observation
I don’t there’s an correlation between your clogged drain pump and the leak. One thing I run into a lot is house drains backing up. It’s possible yours only leaks whenever you’ve accidentally used too much soap.
You have to look for where you see evidence of water coming from. The front or the back, or underneath. As far as your house drain, you can stick a rag or something up there near the drain so that if it ever backs up, the rag will be wet
  • 1 year later...
boost505
did you figure out the problem?
I've got a Samsung front load with the occasional leak as well. water pools on floor under the filter cover.  different model.
