MsAnn Posted October 23, 2019 Share Posted October 23, 2019 Manufacturer: Ge Type of Appliance: Range stove oven/slide in Model Number: RB753BB1 Have you validated the model number at an online parts site like Repair Clinic? (yes or no): Ye Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): Yes Jesus H Christ. I moved into a rental/same complex but downstairs. the the front right burner 8” Is Not consistent as far as temp. When I open the oven door there is heat. Not too hot but warm. I am looking for a wiring diagram so I can verify there is an issue with the infinity switch and or control. I know you are wondering why the maintenance department can’t do this. not sure I suspect they do not know how to work on or troubleshoot appliances. I realize this appliance is old as F... but I need a wiring diagram. Can you help. I feel like a big DA for even asking. if you can help that would be awesome. thanks Ms Ann Link to comment Share on other sites More sharing options...
EthanRanft Posted October 23, 2019 Share Posted October 23, 2019 (edited) No luck on my end. But I’m confused with your symptoms. This should be straight forward troubleshooting without a wiring diagram. If you’re having problems with a surface element, the EOC will have nothing to do with that. If you need more help, we should be able to walk you through it if we can’t get the wiring diagram Edited October 23, 2019 by EthanRanft Link to comment Share on other sites More sharing options...
Captain Dunsel Posted October 23, 2019 Share Posted October 23, 2019 Uploaded mini manual. Waiting on approval. 1 Link to comment Share on other sites More sharing options...
EthanRanft Posted October 23, 2019 Share Posted October 23, 2019 The Captain is the best at providing service documents! Link to comment Share on other sites More sharing options...
MsAnn Posted October 23, 2019 Author Share Posted October 23, 2019 8 hours ago, EthanRanft said: No luck on my end. But I’m confused with your symptoms. This should be straight forward troubleshooting without a wiring diagram. If you’re having problems with a surface element, the EOC will have nothing to do with that. If you need more help, we should be able to walk you through it if we can’t get the wiring diagram Oven stays on, surface burner No temp range. Off, med and hi is all I get. I want to test the EOC AND replace the Infinity Switch. Link to comment Share on other sites More sharing options...
Team Samurai Son of Samurai Posted October 23, 2019 Team Samurai Share Posted October 23, 2019 Thanks @Captain Dunsel! Link to comment Share on other sites More sharing options...
MsAnn Posted October 23, 2019 Author Share Posted October 23, 2019 That is perfect. Thank you! Link to comment Share on other sites More sharing options...
