service Manual for fridge M#111.71212611
fillthebarman
Manufacturer: Kenmore
Model Number: 111.71212611
Is this a good idea to  work on this?
Thanks.
Phil
  • fillthebarman
  • Son of Samurai
It's a Kenmore made by Daewoo, which means you're going to be hard pressed to find any info on it for prediagnosis (I certainly can't find anything). Finding parts could be tricky, too.
