Ge washer
Gmaire02
Manufacturer: GE
Type of Appliance: Washer
Model Number: GTW460ASJ9WW
Washer is not draining or spinning.   Looking at it tomorrow.
Thanks
  • Captain Dunsel
  • Gmaire02
These service bulletin may apply or not! https://appliantology.org/search/?q=HL03-18
HL04-18 Top Load Washer Intermittently Spinning Service Bulletin
HL03-18 Top Load Washer Cycle Not Starting Or Completing Service Bulletin
HL06-17 Top Load Washer Excessive Vibration or Moving Service Bulletin
HL07-17 Top Load Washer Pressure Chamber Port Flash Service Bulletin
HL03-17 Top Load Washer Excessive Vibration or Moving Service Bulletin
HL08-16 Top Load Washer Water Leak During High Water Level Service Bulletin
HL06-18 Top Load Washer Not Pumping Water Out Service Bulletin
Edited by Captain Dunsel
More information
