Kenmore front load service manual?
jtelepan
Manufacturer: Electrolux Kenmore
Type of Appliance: Front loader washer
Model Number: 417.41942710
Unit not going into high speed spin. Service manual is mos def needed please.
  • jtelepan
  • Captain Dunsel
You should be able to use this service manual.Also uploading wiring diagram and Parts list with wiring diagram in it to.Waiting on approval.
Thank you. I’m in the midst of wargaming my Pre-diagnosis and strategy before I get to the call again. I don’t see an option to get into test mode or Pull error code history. Are you familiar with this unit or any other literature available with that?
