ELT-21V-40A40 Kendro laboratory products
goliad
Low temp freezer not cooling.  Fan runs. Coils have been cleaned. Compressor not running.  Need help to diagnose start relay and control board.
Thanks!!
  • Replies 0
  • goliad
