WRT318FZDW02 Tech Sheet/Service Manual
bigmoe_725
Manufacturer: Whirlpool
Type of Appliance: Fridge
Model Number: WRT318FZDW02
Saw a job aid for WRT318FZDW01, will this be the same for WRT318FZDW02?
Also is there a tech sheet and/or service manual for this model?
Thx
Moe
Edited by bigmoe_725
Uses the same tech sheet as this one.Service manual R111 or Job Aid W10330404 does not seem to apply if that is what you saw! But does come up at servicematters for that model.Just don’t seem to match!
Edited by Captain Dunsel
Spelling
  • Thanks 1
  • 1 year later...
that tech. sheet shows swt. 1 and then 4 led's. WRT318FZDW02 only has 3 led's. Should be a specific tech. sheet for that. Just for future reference. My customers was freezing fresh food. Found ref. thermistor out of range. Just FYI.
