Thermador PODC302/01 Wall Oven Service Guide
EthanRanft
Manufacturer: Thermador
Type of Appliance: Double Wall Oven
Model Number: PODC302/01
I have the service manual, just looking for the service guide now
  • Replies 6
  • EthanRanft
  • Son of Samurai
I'm not finding a service guide -- just this manual, which I assume is the one you have:
Thanks for checking. Yes I have that one. The one that’s supposed to be behind the control panel, the tech sheet, is missing
@Son of Samurai do you see one for any of these: POD301, POM301, POMW301, POD302? I mostly just need information on service mode and maybe a good wiring diagram. The service manual explains how to get into service mode, but nothing about what you can do within it. And there’s strip diagrams, but a full schematic would be nice
Edited by EthanRanft
🙌 YES! Thank you!
For some reason that tech sheet doesn’t provide much information on service mode either. It says:
“In Service Mode, all components can be manually tested. For more information on Service Mode and other troubleshooting tips, refer to the service manual or QuickFinder”
Nothing much that I see in the service manual. Do you possibly have access to this “QuickFinder”, @Son of Samurai?
I do, but I'm not finding anything more about service mode, sadly...
