Jenn air range Tech. info
AllStarBob
Manufacturer: Jenn -air
Type of Appliance: Stove
Model Number: JGR8875QDS
 Going out on this call this morning. I found PUB 16027183 but through a different mo.# not sure if it would work. I have a customer complaint that the cook top works fine but when he goes to turn on the oven he gets a sputtering noise.
  • Replies 1
  • Son of Samurai
  • AllStarBob
