kenmore oven Tech sheet request
Dustin B
Manufacturer: Kenmore
Type of Appliance: oven
Model Number: 79099513
electric unit with 2 ovens
Tech sheet available once approved:
But you’ll need a complete model number to get the correct wiring diagram
EthanRanft is correct you need 3 more number for a complete model number. Uploaded wiring diagram 318045321b for 79099513300 pending approval:
