GE Dishwasher: GDF610PGJ2BB Drain Pump Running Nonstop
Whyclef
GE Dishwasher (GDF610PGJ2BB) water would not drain so replaced drain pump on Friday, May 29th. The first two loads it ran with no problem. Today the drain pump runs nonstop and the control panel is not counting down from estimated time. Guessing the drain pump burnt out because of this same issue. The dishes appear to fully cycle and be clean but not dry. Searches of similar issues with GE Dishwashers have led me to believe it might be the Flood Switch or Control Board, but that is a guess. Any advice on what might be causing this problem?
  • Replies 1
  • ABA Tech
  • Whyclef
Food and soap easily gets stuck inside that style float switch which messes it up, and the float switch also contains a thermistor which if out of spec will cause the heater to not turn on. I wouldn’t be surprised if your float switch is the culprit for the constant draining as well as the dishes not drying.
