Whirlpool front load washer tech sheet/service manual/parts list diagram needed model WFW9500TW01
Oservice
Manufacturer: Whirlpool
Type of Appliance: Front load washer
Model Number: WFW9500TW01
Hi
I'm looking for a Whirlpool front load washer tech sheet/service manual/parts list diagram for model WFW9500TW01 which would also include the schematics and parts diagram/list.
Model # WFW9500TW01
Serial # CSW4108911
2 minutes ago, WOOKIE said:
Correction WFW9500T
You mean here?
5 hours ago, Oservice said:
Do you know if this washing machine uses 1 or more shock absorbers (part # W10822553)?
I don't see that PN in the parts manual, so it would seem it doesn't use those.
The part number in the parts manual is 8182812 (illustration #28 on page 7 and 8.  However that is the old part number.  When you plug that part number into repairclinic.com it tells us that that that part number has been replaced with W10822553.
https://www.repairclinic.com/Shop-For-Parts?query=8182812
https://www.repairclinic.com/PartDetail/Shock-Absorber/W10822553/4273183
I wanted to know how many shock absorber this model washer uses.
Gotcha. Not sure why the parts manual only shows one (guess they got lazy), but usually there are four of those -- two on the front, two on the back.
4 shock absorbers then.  That's what I needed to know.  Thanks.
