Bosh Dish Washer
Gregg
Model number shu4302uc. This unit will not come out of the wash cycle.  If you turn it of and then back on right back to washing.  Tried disconnecting power, but went right back to washing.  Would this be the control board? Thanks Gregg
  • Replies 4
Some good information on what to look for on the control board here: http://fixitnow.com/wp/2006/06/09/bosch-dishwasher-takes-forever-to-complete-a-cycle/
Let me know if that's not it. if it is, easy fix I even have a slick little soldering how-to pdf if you need it. :cool:
[user=4006]Gregg[/user] wrote:
I'd like to read your soldering pdf.
Here y'go, Buddy-row (attachment). Yep, usually just re-making that burnt solder joint restores dishwasher bliss. Sometimes, though, that relay gets taken out so you gotta replace the whole board.
How_to_solder_1.pdf
