Frigidaire refrig tech sheet for LGHT1846QF0
1manoperation97
1manoperation97
Manufacturer: Frigidaire
Type of Appliance: Top mount refrigerator
Model Number: LGHT1846QF0
Can't get the b2b site to work, can I get this here?  This refrigerator has the sliding temp control on the left hand side.   Thanks, James
Behind the scenes, the b2b site uses a protocol called FTP, not HTTP which is what all websites use.
This worked fine for the past 30+ years, however due to low usage, Google turned off FTP support in Chrome.
You can turn it back on by typing "chrome://flags/" into the URL bar in Chrome, then type "ftp" in the search box and switch the setting for FTP from "default" to "enabled".
This will make it work for "a while" where "a while" is defined as "until Google gets around to actually removing the code from Chrome".
Terry
Edited by Terry Carmen
  • Like 3
  • Thanks 2
Works find on Safari also heard it works on Firefox:
Edited by Captain Dunsel
anyone know the work around for FTP on Firefox?
Not really. FF apparently has an axe to grind and FTP isn't going to come back.
1manoperation97
Thanks Terry, tried the fix by changing protocols to enable FTP. This worked great!
