Not cooling that well at all Refrigerator Whirlpool Model # ET1FTEXMQ01
netsurfer802
netsurfer802
I  have a Whirlpool fridge that isn't working nearly as well as it should be ...I have the cold
settings set the highest that it can go and it's not nearly as cold as it used to be
in both the freezer and the fridge part.
About at least a a year ago I had to replace some parts that went bad when I had this same or similar problem...but I forgot what parts they were.
Besides being pretty much silent I'm hearing a faint clicking noise once in a while.
I'm wondering how can fix this?  About how much would it cost for parts?
Would it be more worth it just to get another one?
  • Scottekarate
  • Josh Smith
  • netsurfer802
Where is the click coming from? Do you hear the compressor running? Do you hear the fan running in the freezer? Do you feel the airflow from that fan to the refrigerator compartment? Is the fan in the compressor compartment running? Are the condenser coils super hot or room temp?
