Kenmore (LG) 795.51823.410 service manual needed
tonkyman79
Manufacturer: Kenmore
Model Number: 795.51823.410
Have you validated the model number at an online parts site like Repair Clinic? (yes or no): YES
Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): YES
Need service manual for  Kenmore 795.51823.410 please. The Manual on this site that matches part of that number is for a different refrigerator.
I appreciate your help.
Tony T
I see you download one.Anyway does this one get you closer? I know it has  795.5182
  • Thanks 1
The manual @Captain Dunsel posted covers these models:
79551822411, 79551823411, 79551829411, 795.51822411, 795.51823411, 795.51829411, 79551822410, 79551823410, 79551829410,
  • Like 3
Thanks guys... That one has the correct connector and pin-out colors.
  • 1 year later...
thanks for the upload!! i have a question. On page 23 it says something about putting 3way valve into home (bothopen) position to perform a vacum or im assuming any sealed system repair. But it mentions disconnecting the 3way valve housing. Here exatly what it says down below word for word. Are they refering to the wiring connector? Gotta be right because if the 3 way valve is totaly removed they can be no vacuming. This literature has to be a mistake
     "Note: Before processing the vacuum, the 3 way valve status should be “both-open”. You can make the 3 way valve “both-open” following as below.
1. Turn the refrigerator on, and open the Fresh food door.(Ref Door).
2. Keep Opening the Fresh food door(Ref door), press 2 buttons “Ice plus(or Ultra Ice) and Ref. temp” on display for 3sec.
3. “OFF” will be shown on the display. (Demo mode : bothopen status).
4. Disconnect 3 way valve housing.
5. Turn the refrigerator off and proceed the vacuum.
6. after recharging the gas, connect 3 way valve housing.
