ISO Main Board Replacement Programming Literature
MarkWisdom
MarkWisdom
Manufacturer: GE
Type of Appliance: Front Load Washer
Model Number: GFW650SPN
I have replaced the main board in a GE Front Load Washer. Full model number is GFW650SPN0SN, last bit is just color but felt like it should be represented as it is on the appliance. Anyway, plugged it in and need to program the bugger. I have downloaded and searched through a couple service manuals for proper method as what to do after replacing the board but have come up short. Any help would be greatly appreciated, thank you in advance!
  • MarkWisdom
  • Son of Samurai
I believe I tried those and they did not have the info needed. I ended up finding the documents on GE's service site. I uploaded those documents for anyone else that ends up in a similar situation. Thank you very much though!
