Kenmore gas wall oven model # 79040292410 service manual needed
drew 83
Manufacturer: Kenmore
Type of Appliance: Gas wall oven
Model Number: 79040292410
Kenmore gas wall oven model# 79040292410 service manual needed. Found manual for electric oven that is similar but i need the gas oven manual, thanks.
  • drew 83
  • Son of Samurai
  • Captain Dunsel
