    • 15 February 2025 03:00 PM Until 04:00 PM
      Returning guest presenter Aaron Wilson is back for another exciting discussion. This time, we'll be talking about...
      The Science of CYA: How to Keep the Customer Safe, Document Your Work, and Not Get Sued
      We take on a lot of liability as appliance repair techs, and that can get us into sticky situations whether we've done anything wrong or not. Aaron will be teaching us all about how to navigate this side of the trade.
      We'll start by going over a tragic, real-world case study where a sloppy installation had lethal results, analyzing exactly how the installer's negligence caused this. From there, our scope will expand to what kind of safety precautions we should implement in our own work, both for the customer's sake and for our own.
      But even if you do everything perfectly, there's still the famous "technician witch hunt." Well, we'll also talk about how to deal with that by thoroughly documenting your work and putting yourself beyond legal reproach.
      A little about our guest, Aaron Wilson:
      Aaron has been in the appliance repair trade for about 15 years, starting out by doing installations before moving on to bigger and better things. He worked for C&W Services as a Sub-Zero authorized servicer for a time and thereafter joined Mr. Appliance of Highland Park in the Dallas area, where he worked for years as the lead technician and field service manager. These days, he's making sure that all the appliances of everyone's favorite fried chicken place are in tip-top shape as the Quality and Performance Consultant for the southwest branch of Chick-fil-A. In addition, he has taught many classes on refrigeration repair and advanced diagnostics, during which time he also developed training material for the soft skills side of things, which he is delighted to share with you. On top of all that he's a certified graduate of the Master Samurai Tech Academy, so he knows his stuff!
      When: Saturday, February 15 @10:00 AM Eastern Time.
Replacing old air conditioner (plug type and voltage problem)
stevem01
Hi,
Our 20 year old air conditioner went out. The plug doesn't match any of the plugs that are displayed on HomeDepot's website.
The existing plug is 250 Volts / 30 Amps. The ones at HomeDepot are 115 or 230 volts and 15 - 20 Amps.
What are my options? Do I need to have an electrician install a new outlet? Use an adaptor?
Here are two pictures of the existing outlet and plug:
Steve
  • Replies 7
click on picture
Sorry I must have forgot to say that the air conditioner is no longer working (just a buzzing sound like it wants to start). I was going to replace it by buying a new unit from HomeDepot, but all of the plugs shown at the HomeDepot website are not 250V / 30Amp... they're all 230V / 15Amp with different connectors / plug configurations.
In other words, if I buy a new AC from HomeDepot then the plug will not be compatible and the volts and amps are different on those.
Any suggestions?
how big an A/C unit are you buying .. ?
the big ones are only available in 230v
It's a window AC unit and based on their configurator it said I needed approx 20,000 BTU unit, so I was looking at their bigger 230 volt 30amp units.
OK, so either change the Wall Outlet to match the new A/C
or change the plug on the end of the new A/C to match the Wall Outlet.
Looks like a NEMA 30A twist lock, typical for boats and campers, used to plug in to dockside or site power at 120 VAC.
What rating do you need for your new unit, that's the question. And what's the rating for that wiring into the junction box? It will be printed on the jacket. Not likely more than 20A, anyway.
you already have the 30 amp plug
get the new unit as then take the plug off the old one and fit to the new one if it is still servicable
