fan does not always work in heat mode
#21
Posted 27 December 2011 - 10:38 PM
"May the hinges of our friendship never grow rusty"
-old Irish saying
Buy me a Beer: http://web.me.com/ze...man18007260692/
#22
Posted 28 December 2011 - 08:44 AM
#23
Posted 28 December 2011 - 09:03 AM
#24
Posted 28 December 2011 - 02:49 PM
#27
Posted 29 December 2011 - 07:58 PM
#28
Posted 29 December 2011 - 08:17 PM
You need a reading from yellow and most likely black to the fan motor when it stops running.
If you have 220 volts the fan motor is bad.
If you have no volts and the heaters are still on,you have a fan relay problem.
#29
Posted 30 December 2011 - 03:06 PM
-old Irish saying
#30
Posted 31 December 2011 - 02:23 PM
#31
Posted 31 December 2011 - 03:41 PM
Edited by applianceman18007260692, 31 December 2011 - 03:42 PM.
- kdog likes this
-old Irish saying
#33
Posted 31 December 2011 - 07:29 PM
#34
Posted 31 December 2011 - 10:52 PM
jumptrout when the heat and fan are off, amp draw on the yellow and black leads are .02amps. I'll check for voltage to the heat strips in the am.
RegUS_PatOff I took a look at the install manual, wiring diagram mateches to what is in the unit...
#35
Posted 31 December 2011 - 11:20 PM
It feeds back to the right side of the sequencer that has all the devices attached to it pic DSC03165.
#36
Posted 01 January 2012 - 08:45 AM
1. Put your amp meter on a heater wire.
2. Turn the heater on.
3.Heater comes on followed by the fan.
4.Fan stops running.
5. Are the heaters still drawing amps when the fan quits?
6. If heaters are drawing amps,does the fan motor have 220 volts measured at yellow and black?
#37
Posted 01 January 2012 - 08:52 AM
All this is normal.Ok went ahead and took a look at the voltage on heat coils after thermostat shuts heat off. Has 120v to it, looks like it is coming from the light blue wire on the circuit boardrelay look at pic DSC02168 on page one, it is a dark blue once it passes thru wire connector.
With the thermostat satisfied you will always have half power (120 volts) to one side (incoming) from the pwer supply. The other leg is made through switches and relays on a call for heat.
This provides 220 volts to the fan and heater.
#38
Posted 01 January 2012 - 01:46 PM
#39
Posted 01 January 2012 - 01:49 PM
Either I am not writing correctly or you are not interpreting correctly. 1. Put your amp meter on a heater wire. 2. Turn the heater on. 3.Heater comes on followed by the fan. 4.Fan stops running. 5. Are the heaters still drawing amps when the fan quits? 6. If heaters are drawing amps,does the fan motor have 220 volts measured at yellow and black?
After the heat cycle, fan is off and thermostat shows no "heat on" the heat coils show no amp draw.
#40
Posted 01 January 2012 - 02:24 PM
This a normal situation. Everything should be off when the thermostat temp is satisfied.After the heat cycle, fan is off and thermostat shows no "heat on" the heat coils show no amp draw.
However,it has nothing to do with how you stated your original problem of the fan cycling off and the heat staying on.
I am going to take the opportunity to move on to other post and actually help someone.
